HELP... Nitrous warm up procedure in staging lanes
Old 07-24-2014, 07:08 PM
samsperformance's Avatar
Default HELP... Nitrous warm up procedure in staging lanes
I have a few questions i want to clarify, i am sure the info is already on here but i cant find it. I am running a single stage fogger on a LS1, Pro shot NOS solenoids. NOS bottle blanket.
When i warm my bottle in the trunk i put a stand alone gauge on the bottle so i could read the gauge and the pressure didnt go to the nitrous solenoid. When nearly ready i take the stand alone gauge off and reconnect the line, turn the bottle on and the pressure dropped from 950 PSI to 800 PSI just from filling the line
1. How do you guys warm your bottle and whats your procedure for keeping the pressure up in the staging lanes?
2. Is it safe to let the bottle pressure go against the NOS solenoid with the engine off while warming the bottle in the staging lanes?
3. Do you turn the bottle off and purge the lines down between runs or just turn the bottle off and leave the lines full? (I have been doing this but i waste a lot of nitrous)
Your help is greatly appreciated, Thanks in advance
Old 07-25-2014, 08:41 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
A heater should be able to keep the pressure up pretty easily. If its not doing its job, the heater is either on its way out, or the bottle could be close to empty, then it will become hard to keep it pressurized. You can get a bottle pressure gauge and swivel manifold that will mount the gauge right off the bottle so you won't have to empty the lines everytime. It does not hurt the solenoids leaving pressure on them when in the pits and such, but for peace of mind I empty my lines if I know the car will be sitting for an extended period of time.
-Garrett
Old 07-25-2014, 09:07 AM
ss performance's Avatar
-Garrett
What he said.
Also not all bottle warmers are created equal. So if it is not getting to pressure it might be too small.
You can get a pressure switch that will turn the warmer off when it the pressure reaches a predetermined pressure.
Also if you have a AC source you can get warmers that are AC/DC. With these you can get the bottle to pressure in the pits then the DC just maintains the pressure in the lanes.
I know a company that makes the above mentioned items. If you PM me I can give you their name.
Good luck.
Old 07-25-2014, 09:33 AM
brandon@nitrousoutlet's Avatar
What are you using for a heater in the pits?
You could try raising your bottle pressure initially to around 1050 to offset the pressure loss from filling the lines.
You can leave pressure against the solenoid as long as your pressure doesn't creep up really high which could dimple the piston and hurt the solenoid.
Between rounds I'm swapping bottles.
Old 07-25-2014, 10:18 AM
BSmiff's Avatar
Or if you want to keep the setup like you have now you could add one of these in line a lot closer to the solenoids. Your pressure drop wont be as extreme if you heat the bottle and keep this closed.
http://www.nitrousoutlet.com/plumbin...ff-valves.html
Old 07-25-2014, 10:29 AM
That's a good option and would keep him from having to disconnect the bottle over and over between rounds and keep pressure off the solenoid.
Old 07-25-2014, 10:44 AM
BSmiff's Avatar
And I bumped your product at the same time
OAN: I just ordered a purge kit from you guys. I still have to hook up the kit I bought but Im sure the purge will be the same quality I have come to expect from Nitrous Outlet.
Old 07-25-2014, 12:02 PM
Right on man lol
Get that kit installed!
Old 07-25-2014, 01:57 PM
JDEP162's Avatar
i use the heated bracket bottle mount with pressure controlled switch. works great. i usually open botlle and turn heater on when they call my tire class, makes about 25 mins or so before a pass in the staging lanes. if its longer than an hour till next pass i shut down and close bottle. bracket heater is from nitrous outlet.
Old 08-22-2014, 11:20 PM
camarokid94's Avatar
Open the valve very slowly!!!! Pressure drop is less when it's not sudden
Old 08-25-2014, 09:46 PM
blacktransam's Avatar
All the "big names" in here and every one missed the real problem. Unless your bottle was empty, you didn't lose 150psi opening the valve. I don't lose that opening a -8 feed. You have a faulty gauge somewhere or your bottle was empty
Old 08-26-2014, 08:46 AM
My guess is the bottle was probably almost empty.
-Garrett
Quick Reply: HELP... Nitrous warm up procedure in staging lanes
