Nitrous WOT switch or not?
Old 09-05-2014, 12:02 AM
mcmuscle3's Avatar
Default Nitrous WOT switch or not?
hey guys, I have a nitrous outlet kit i bought second hand, I purchased a jegs window rpm switch. I do not have anything to control the nitrous other then the window switch. I was wondering do i need a WOT switch also, or will the window switch be good enough?
Old 09-05-2014, 04:11 AM
HCI2000SS's Avatar
I thought a WOT switch was standard on all kits. If not then yes you want one
Old 09-05-2014, 08:46 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Yes you will need and want a microswitch. You can still use the RPM window switch in conjunction with a WOT switch. If you have any other questions, let me know!
-Garrett
Old 09-05-2014, 09:45 AM
brandon@nitrousoutlet's Avatar
When you buy them new yes.
To the OP, unless that window switch has a built in TPS, you will need a WOT switch.
Old 09-23-2014, 03:28 PM
FEAR LS's Avatar
I have the exact same setup and can shed some light if you haven't figured it out yet.
Quick Reply: Nitrous WOT switch or not?
