Good Starter Kit?
Good Starter Kit?
Hey I was just juggling the idea of doing nitrous when I did a fast 102 and bigger injectors on my ls1. if I go with a fast 102 what all would I need to spray with it? is there a certain 'Kit' or would I have to order individual parts and what all would I need to put the juice to it? I'm new to the nitrous world so any help would be very welcome.
still a nitrous rookie but il try to help, first decide if u wanna go wet or dry, wet is fuel mixed with nitrous before injected, dry sprays just nitrous and ur fuel system adds extra fuel.
u can vo with nozzles, or a plate.
best advice ii van give ya, contact nitrous outlet directly, they can set u up for exactly what u want/need.
i pm'd brandon@nitrous outlet in this forum, a couple days and few emails and i had a proffesional quote and placed an order, alk safety gear included.
I would suggest that you go with something like a Nitrous Express plate kit "which is a wet shot". I believe they make one to fit that intake. It goes between the throttle body and intake. A plate would give you better atomization and distribution than a nozzle. I also suggest it because I prefer wet kits over a dry kit because all you depend on is the fuel pump being able to keep up, as opposed to depending on the injectors and fuel pump..... just my 2¢
A wet kit also depends upon a fuel solenoid to supply fuel...debatable what is more reliable between the solenoid and fuel injector.
Both systems have their advantages, and set up properly both work great.
Ls1tech & Truck Sponsor
We make a really nice bolt on plate system for the 102mm setup. Heres a link to it...
http://www.nitrousexpress.com/20933-...lb-bottle.html
You could also do a single nozzle system that mounts in the intake tube...
http://www.nitrousexpress.com/20421-...lb-bottle.html
Both of these systems are complete with everything you need, including a bottle. They do not include any accessories but they do have everything you need to get started. For accessories I would recommend a heater to keep bottle pressure, and an RPM window switch to make everything a little safer.
Let me know if you have any questions or if you need forum pricing on these items.
-Garrett
-Garrett
-Garrett
-Garrett
My tuner said to go with the wet kit because that's what he runs on his ls2 GTO. I also like the fact that it seems much less of a headache than a dry shot. Say I was going with a 100-150 shot would I need a new fuel pump? is the wet safer than a dry kit? I don't want to destroy anything the block is all stock other than cam, oil pump and chain.
-Garrett
On a completely stock LS1 we were able to spray 200 with the factory fuel pump. Being that you are modded, you may look into another fuel pump. I imagine you could probably run 100 shot with no issues at the pump. A wet system is easier to setup definitely, and the fuel enrichment is provided through the fuel solenoid instead of the injectors. A dry system could be just as safe, if the tuner knows what he is doing. (Which I'm sure he does.) I will tell you that about 90% of the systems we sell for LS cars are wet systems.
-Garrett
-Garrett
