Need help mounting money maker solenoids
Old 09-17-2014, 09:04 PM
Centerfold_Firehawk's Avatar
Default Need help mounting money maker solenoids
I have a intake recently plumbed with the nitrous outlet money maker kit and I want to know and see where other people have located there nitrous and fuel solenoids and remain stealth and well hidden pictures would be awesome and I'm not trying to get or show pics of the moneymaker install just the solenoid locations thanks all
Old 11-08-2014, 10:54 PM
highway21's Avatar
I also would like to know... I was thinking about in the cowl under the wipers
Old 11-09-2014, 06:43 AM
Doug G's Avatar
Would a oil/air separator be an option (gutted) and could add black vacuum line over N2O lines to keep them hidden ?
Just throwing an idea out.
Old 11-09-2014, 08:25 AM
Zmg00camaross's Avatar
Call up nitrous outlet. That was easy!!
Old 11-09-2014, 06:02 PM
maroonls1z's Avatar
They make mounts that bolt to the heads. I was going to mount them to the back of the heads. Not completely hidden but you would probably have to get far in there to see them
Old 11-10-2014, 09:50 AM
brandon@nitrousoutlet's Avatar
That's a cool idea! Our instruction state that you will need to get creative on solenoid mounting. There is no one "right" location. It is up to you.
Old 11-12-2014, 04:29 PM
Majestic9C1's Avatar
Mount them on the inside of the airlid cover and run the wiring right next to the IAT sensor wires
Old 11-16-2014, 09:55 PM
SMEC-SS's Avatar
I see your car is a M6. I mounted mine on the tabs that are on both sides of the tranny. Made brackets for them and then found the hardware at lowes to mount them up. Passenger side of the tranny had the nitrous noid and the driver side had the fuel noid. I ordered custom line to go from tranny to the money maker. Very simple setup. I had 2 kits on the car too...
Get creative and make it happen
Quick Reply: Need help mounting money maker solenoids
