plugs 200 shot
plugs 200 shot
Sprayed 200 shot , plugs had no idle time one pass turned it off , pulled plug.
i am thinking add 1 degree of timing , leave fuel alone, i pulled 9 on this run
plugs B8EFS, fuel is 93&Pro-120 Nitrous in a stand alone .078,.042 jets, well close to a .042 used a drill bit.
All opinions welcome
no just reading plugs, 93 octane and renegade pro 120 nitrous fuel in a stand alone fuel cell when i spray, the renegade does have orange dye in it. not use to reading plug this way, may put it on a wide band and see
I'd put a wideband in it and see what that says. Obviously don't use the wideband for making ur decisons on adjusting ur fuel but use it to give u an idea what is going on. I run c16 my plugs come out pretty clean. That fuel is kinda throwing me off on what ur car wants.
gotcha, wondering on my stand alone fuel cell how much fuel pressure i need to drop before i see a change, its at 55 psi, not sure read bunch of information seems wishy washy some of it saying 5 lbs all the way up to 10 lbs of pressure before change can be seen , bought system used with high pressure spring in the regulator may change it over to a low pressure set up to aid in tune ability for me , i feel uncomfortable with the high pressure tune ,not sure guess it would not hurt me to learn. Biggest thing with me is not wanting to torch any thing over making assumptions.
The alternative as stated, less fuel. If it runs lean, it will seem like its running smooth but won't be making the power and won't MPH.
Old School Heavy
Those NGKs start to flake just before they leave a burn mark on the ground strap. I don't see a distinct mark on this plug, but he is close.
I tend to agree with you. add 1 deg and leave fuel alone.
Thanks guys, for some reason i think my 4an feed line is restricting nitrous flow, so i'm going to put an 6an on it and use the dyno to help get the air/fuel right.
what you think good target for air/fuel? (12 to 1)
Looks aggressive on timing to me... and rich on fuel.
You are pulling 9* from what base number?
78N jet is closer to 250 than 200.
If it was mine I would pull 3* out and try 40f jet.
He has it jetted in accordance to Nitrous Outlet's charts. .078N jet on their plate is a 200hp jet. They ask for a 44F jet @55psi. Obviously that's going to be rich. I'm sure that's why he was going with th .042F jet.
What AFR's were you at?
I too would like to know what base number he's pulling 9* from. I mean going by the rule of thumb he only had to pull 8*, however if the timing has been ramped up for NA use then the base number may have been too high of a starting point. I'm learning from this thread as well. I'm kind of in the same situatuon.
FYI, the 78/44 combo on my car a while back at 55psi, gained 239rwhp and was 11.8:1, exactly where my car runs best. Their low pressure, direct port jetting in my car was way way off in the rich direction.
