Does added compression affect the suggested fuel jet size?
Old 10-06-2014, 04:48 PM
poltergeist 02's Avatar
Default Does added compression affect the suggested fuel jet size?
I know there are suggested starting points when it comes to nitrous/fuel jetting, but does added compression affect the suggested (starting point) fuel jet?
Old 10-06-2014, 06:49 PM
HCI2000SS's Avatar
I'm pretty sure not enough to alter it. I'm 11.5 compression and run a 52/28 for my NX 100 shot, which is standard
Old 10-06-2014, 08:01 PM
cool, thanks. I'm new to nitrous and just want to be sure before I go and screw something up with a stupid mistake.
Old 10-06-2014, 09:22 PM
Dynospeed's Avatar
Just pull a little extra timing and you will be fine.
Old 10-07-2014, 08:23 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
This. Race fuel helps with the timing, as you already probably know. Higher compression doesn't affect the fuel jet size, but more timing will have to be pulled.
-Garrett
Old 10-07-2014, 09:11 AM
I was planning on pulling 4* for a 100-125 shot. Should I pull 5* for the added compression?
Old 10-07-2014, 09:40 AM
HCI2000SS's Avatar
For reference, with my compression I ended up pulling 3 degrees for a 100 shot
Old 10-07-2014, 09:46 AM
What compression ratio are you running?
-Garrett
Old 10-07-2014, 10:15 AM
It's only 11.5:1
Old 10-07-2014, 10:35 AM
I'm also running a window switch. I'm running a larger converter that was designed for a max effort n/a setup. Do you think I should set the switch to cut out @ 6700?
Old 10-07-2014, 10:49 AM
I would set it to cut out about 200 rpm's before the rev limiter. At 11.5:1 I would just pull 3-4*per 100hp and go from there.
-Garrett
Old 10-07-2014, 11:04 AM
So you think I should spray through the shifts? The current tune is for n/a, I wasn't shure if it would bounce the rev limiter if I were to spray through the shifts.
Old 10-07-2014, 11:08 AM
HCI2000SS's Avatar
My a/f was 11.8 with 3 degrees pulled for the 100 shot, and the pills were 52/28. You'll be fine at 3-4 degrees
Old 10-07-2014, 11:20 AM
That's where a window switch comes in handy. I would use the MSD 8969 on your application if you decide to go with one. Otherwise, you don't want nitrous spraying off the limiter. No bueno. Haha.
-Garrett
Old 10-07-2014, 11:29 AM
inssanity21's Avatar
I only needed 4 degrees pulled for my 150 at 10.5 cr. I have nothing pulling the timing and didn't lose anything noticeable from being down the 4 degrees. If you want some help installing let me know, I would be more than happy to help.
Quick Reply: Does added compression affect the suggested fuel jet size?
