best route to spray 200 to 300 shot
Greetings
Around here they dont want to spray a lot on plastic intakes because 7&8 pistons run lean.
Around 200 shot they swap to a victor jr and spray from a plate.
If I want to spray 200 TO 300 SHOT ON MY STOCK INTAKE should I go direct port, a plate designed fot TB or just swap to a single plane intake?
Thanks for your help
direct port is always safest. Plenty of us spray 300s on plates- a handful spray 250-300 on a SBE.
Good plugs, good tune, standalone with good fuel are a must.
Progressive controller helps. But be prepared: a 300 on a SBE engine isn't going to live forever.
Ls1tech & Truck Sponsor
There is plenty of people spraying 200-300 on a truck intake. If you put a direct port on a plastic intake, that is the safest as far a cylinder to cylinder distribution, and it gives you the ability to tune each cylinder. We did a direct port on a factory truck intake a couple weeks back, and we do a few plastic intakes every week.
No problem with spraying 300 on a plastic intake.
-Garrett
-Garrett
