nitrous outlet stock cube ls2 at it again..1.15 60ft
Stock cube stock stroke Ls2 with power glide ptc verter 4.30 gear ported Ls3 heads and Martin Smallwood cam 2900 with me in it.. nitrous outlet stinger plate with a 93 pill
You will like your results. We did the small swap on a ls2 stock bottom end a few yeas ago with tfs 225's. it picked up a little over 3 mph in the 1/4 and liked to be shifted at 7600 compared to 7300. Over the winter get the super ported.
Which size ptc converter are you running? What does it 60' on motor? My 8" ptc is as tight as they can make it and my 10" is super tight from my 440 and alot more nitrous.
Ptc 9 inch with mechanical diode.. goes 4500 on the brake I leave at 3500 off the 2 step..i only made 1 motor pass think it did a 1.5x..I had a 8 inch that was as tight as they coukdmake it and I blew through it swapped to there 9 inch and have not had a problem.. they gave me the full amount I paid on the 8 inch
