Nitrous newb. Help point me in the right direction
Whats up guys looking on some advice for my first ever nitrous set up. I was gonna go with some sort of general EFI kit. I was originally gonna with a plate kit however the engine is in an e30 bmw and the 1'' plate wont allow the intake to fit so a nozzle kit is my only real option at this point. The motor is essentially a stock LQ9 with PSI springs, Tick 227/235 .59 .52 100lsa cam, LS6 intake, block hugger style headers and true dual 2.5" header back exhaust.
The car will be used mainly for roll racing. I also want to be as covert as possible. I am going to do my best to hide everything the best I can. So im seeking out what is the best kit to go with the best size shot and best way to mount it being hidden as possible.
Thanks guys
Thanks guys
Gonna be hard to be stealthy with nozzles, but if you can run them into the bottom of the tube and run the lines under the manifold/fuel rails so they blend in, the kit won't jump out at you. Nobody who actually knows what to look for will miss a nitrous kit though, unless you are going way out of the way to hide it.
Ls1tech & Truck Sponsor
You could use something like this for a nozzle setup..
http://www.nitrousexpress.com/produc...yword=20421-10
However, we can do hidden spraybars inside an LS6 intake, for a very reasonable price. If you want a little more info on this setup let me know.
-Garrett
-Garrett
