ls2 true street nitrous build ''daily driver''
motor finished up and want some of you guys opinions ?
It's a ls2 block bore the 4.005
stock crank
scat rods
dss forged Pistons with -5cc valve reliefs
patriot performance 5.3 heads about 10.6:1
231/239 comp cam
Ls6 intake
Full exhaust
42# injectors
Racetronix fuel pump
Performabulit stage 2 4l60
Fti4000 nitrous stall
3.73 gears
Going in a 98 ss weighs 3500 with me in it 275 60 15 m/t drag radials it's goT comp engineering shocks out back bmr torque arm and sub frame connectors It's got a nos plate on it. motor was built to hold well over a 300 shot guaranteed by builder. ring gaped for n20 will be seeing 200 shot for a while.
what are u guys guesses?
what should it put down?
n/a and with 200 hit
cam choice was based on drive ability and not sacrificing power lost n/a...
stock crank
scat rods
231/239 comp cam
Ls6 intake
Full exhaust
42# injectors
3.73 gears
jaja stock 10 bolt!!! yup stock but for some reason it doesn't want to let go. it was a 273 and it has the thick gear in it 373 and its been holding for it life for quite some time. h/c 4000 stall 175shot and its still there so im trying it out with the new set up. see if it finally lets go.
fast 90/90 or fast 102 what do you guys honestly think? im not a fan. but this is not my build i like aluminum when ur spraying over 200.. will the fast shine way better with this combo. ls6 will be holding way back...
thanks guys. what other intake out there that wont give me heat soak problems aluminum wise? bros thinking on a direct port later on down the line 300 shot. last thing we was is heat soaking or fuel puddling.
down low was a dog!... ms3 6.0 lq9 victor jr full bolt on car ported polished 241 7.3 motor 6.60 150 shot nos carb style set up th400 fti 3800 stall....
Don't waste ur time and money on a nos plate for a stock intake. Unless ur not planning on spraying the car that hard... I ran one and my car didn't pick up anything when I went from a 150 shot to a 225... Really bad distribution. I switched to a nitrous outlet and on the same size shot ( 150) I knocked off a tenth with just there recommended jetting started leaning it out and picked up another and still have more left in the tune. Pretty much went from a 9.96 to a 9.74 and distribution to the cylinders was even
