So, what does happen when a nitrous bottle explodes?
Old 05-26-2004, 05:38 PM
The Bull
DERTY's Avatar
Default So, what does happen when a nitrous bottle explodes?
This is what happens.
http://www.saturnspeed.com/nitrousexplosion.htm
Old 05-26-2004, 05:54 PM
Slow Z28's Avatar
i think those are the same ones from back in the day years ago. Something about how he cut the resistors off the bottle heater so it didnt read anything and could heat up really quick and something else along the lines of he blocked off the blow off valve. then again, that's all internet gossip "legend". shitty either way cause it's like a minature bomb.
Old 05-26-2004, 06:59 PM
Turo's Avatar
yea, that links is quite a few years old, i remember reading it a while back. that was back when i was scared of using nitrous
Old 05-26-2004, 09:26 PM
Brains's Avatar
Dude comes home, puts the car in the garage, and closes the bottle. Dude forgets the bottle heater on (note: NX bottle heater works on PRESSURE -- with the bottle closed, the pressure transducer doesn't see bottle pressure) Dude forgets to shut off bottle heater, goes in house... Well, NORMALLY this wouldn't be too big of a deal -- the burst disc would rupture and other than losing your bottle full of nitrous, there'd be no damage. Well, this guy decided he wanted an NHRA-legal blow-down tube. Kudos for that, but when you install the blowdown tube fitting, its usually best to only put ONE disc in there -- not TWO. So, the safety mechanism of the valve was defeated, the bottle heater was wired directly to the battery and left on, and the bottle valve was closed. BOOM ...
Old 05-26-2004, 09:52 PM
Cheatin' Chad's Avatar
Carelessness will bite you in the *** more often than not.
Old 05-27-2004, 01:34 AM
chrdij's Avatar
Thats a true rice burner for ya
Old 05-27-2004, 06:54 AM
1ScrudeDude's Avatar
OH MY GOD!!!!
Boy, that turned out to be much more dramatic than I thought! A whole through the garage door!
Hoooooly ****......
Old 05-27-2004, 06:58 AM
Brains's Avatar
I love reading his commentary on the email between him and the owner of NX ...
NX: such and such safety bypassed
Doyle: yeah, but blahblahblah
NX: such and such installed improperly, NOT as clearly stated in instructions...
Doyle: ok yea, but blahblahblah
NX: heater switch with red light indicating its ON installed outside of drivers view..
Doyle: so what? blahblahblah a half million dollars and I'll take my site down!!
NX: FU (ok, I added that part)
I'm gessing he didn't get a red cent from NX, because his site is still up, and now he's "demanding" (on his own crappy website) for the bottle valve manufacturer to contact him. I'm guessing he's gonna try to sue them as well
What makes a dolt think you can defeat every safety designed into a system, blow your car up (literally), and be compensated for it??
Old 05-27-2004, 07:08 AM
dlandsvZ28's Avatar
Guess I'm still confused on this one and what really happened.
I cook pizza at 400 degrees, and it will burn up if left in the oven too long even though the temperature of the oven never gets over 400 degrees.
So why would I want to buy a bottle heater that heats up to 400 degrees?
Please tell me that they don't make bottle heaters that heat up to 400 degrees
Old 05-27-2004, 09:17 AM
Fast94bird's Avatar
I read about years ago. What a waste that some people out there will try any thing to get money.
The bottle heater can only get to 400' in free air. "FREE AIR" Is the heater is not strapped to a bottle. You would have to hang the heater by one of the d-rings and turn it on. Also at the temp. the heater is in thermal melt down. The silicon will turn back into a powdered state. Any of the heaters out there can do this. THat is why you have to have it strapped to the bottle, "a heat sink". As long as it is strapped to the bottle the heater will never get that hot 400'. Once the wires get that hot the amy break and loose the connection.
I think all the safety features that are setup and in place but were ignored. Luckly no body got hurt.
Just my opion.
Old 05-27-2004, 10:09 AM
Brains's Avatar
Its not about heat -- its about pressure... He put a blow-down tube fitting on the bottle, and instead of removing the disc that came with it and using the one with the fitting -- I heard he installed BOTH. The disc is designed to fail before the bottle does, but when you put two in place it won't rupture at the proper pressure..
So we have a bottle heater that runs on pressure, but can't read pressure because the bottle valve is closed (mistake 1). He has the heater wired up so it can be left on with the key off (mistake 2). He had the bottle heater wired to a switch in some way he didn't notice to turn it off when not using it (mistake 3). He defeated the single most important safety feature of the bottle - the burst disc (mistake 4).
Old 05-27-2004, 10:46 AM
OneMeanZ's Avatar
So really, this would never happen to someone who knew even the slightest bit what they were doing right? Because it sounds like he had it coming to him....
Old 05-27-2004, 01:04 PM
slow's Avatar
he had n20 on a maxima. Do i really need to say anymore.
I read that site a few years back, and if memory serves me correct some info has been taken down, most likely at 'councils' request, about mistakes he made.
Ryan.
Old 05-31-2004, 10:44 PM
Brandon Boomhauer's Avatar
i remember that, but never went further than the pics of the car....
what a fucktard... he sounds like a 14 yearold in his postings to nx....
Old 05-31-2004, 10:56 PM
1BADFNZ's Avatar
... Ryan.
LMAO that's some funny ****... but damn did it hurt his car
Old 06-01-2004, 09:48 AM
slow's Avatar
Ryan <-- got a 2004 loaded maxima here... never think of the bottle on it.
Old 06-01-2004, 11:39 AM
taqwache's Avatar
uh oh, i just remembered that i have two full bottles on nitrous in my Black SS that is sitting in the sun with the windows closed and it is 95 degrees outside right now. i better take them out.
Old 06-01-2004, 04:07 PM
SDB
SDB's Avatar
I thought bottles could only blow up on rice cars if a chinese gang on motorcycles shoots up the car with Mac-10's ....guess I was wrong...this poor Maxima guy didn't even have Vin Diesel to yell "Naws!" Poor guy, I sure hope NX buys him everything he wants, like a vtech turbo ********** or whatever he may want.
Old 06-01-2004, 04:13 PM
Why on earth would he do this? How could he even do this?
I have an NX bottle in my car and to install the blowdown tube I have to remove the original pressure release and replace it with the one that came from the NX upgrade kit.
This guy is obviously clueless.Did he not get instructions with the kit?
Old 06-01-2004, 08:08 PM
Quickin's Avatar
What an assclown.
