Nitrous Outlet Kit Choices
Ok I plan on hitting my L92 headed LQ9 with a small shot this coming year.
Getting the converter changed for the shot and upgrading to a 400 with a brake from the current Th350.
Plan on 150-200 shot since its a stock bottom end and pump gas
Which kit should I used and why?
Single nozzle or step up to the plate system. I mean is it really worth $310 more for the plate......
http://www.nitrousoutlet.com/x-serie...00-150-hp.html
http://www.nitrousoutlet.com/efi-wet...te-system.html
The single nozzle is maxed out a little over 150HP. Not only will a plate allow you to flow more when you're ready (it flows up to 400hp, 200 out of the box), but it also doesn't protrude into your airway. With a nozzle, you'd have to mount it in front of your throttle body, which can sometimes affect dispersion (the nitrous/fuel mixture will hit your TB before being introduced into your intake). With a plate though, the mixture is introduced directly into the intake from behind the throttle body, allowing better dispersion and atomization.
