nitrous with torquer v2 cam
Old 01-09-2015, 01:32 PM
buddy35thle's Avatar
Default nitrous with torquer v2 cam
Im in the middle of getting upgrades for my 02SS I have a torquer v2 113lsa full exhaust waiting for me to install them. I wanna add nitrous as well how big of a shot can I run and be safe 100-150?. Other parts I have already is a k&n fipk and 30lbs injectors. Stall is gona be ordered the same time I order a nitrous kit.
Old 01-09-2015, 02:14 PM
HCI2000SS's Avatar
I ran that cam with my current setup a while back and hit it with a 100 shot. It's like any basic cam with nitrous...works fine
Old 01-09-2015, 02:23 PM
AJatNitrousOutlet's Avatar
100-150 is perfectly safe on that setup, but you will want to upgrade the fuel pump or get a dedicated fuel system. If you have any questions, feel free to PM me.
Old 01-09-2015, 03:54 PM
Id still need to upgrade the fuel pump? Even with a wet kit?
Old 01-09-2015, 03:55 PM
Did u get any track numbers with that set up?
Old 01-09-2015, 04:49 PM
A wet kit will still pull fuel from the rail. With a cam, you're looking at around 400HP or so, all motor. But if you put 150HP of Nitrous on top of that, you're at 550 hp, that's pretty much the limit of a stock pump.
Old 01-09-2015, 05:01 PM
So to be on the safe side I should change it then. Ill pm you about some of ur products I wanna start shopping around for a kit
Old 01-10-2015, 09:22 PM
jblankenship's Avatar
Mine seems to work well. I believe Carter01 on here runs the same cam with very good results.
Old 01-11-2015, 02:14 PM
Do u have any track time with the set up. I hope to be in the mid to low 11s
Old 01-11-2015, 09:15 PM
Times in sig is on 175.
Old 01-11-2015, 10:44 PM
I cant see your sig through my phone lol
Old 01-12-2015, 08:10 AM
11.41 na. 10.28 n2o
Old 01-12-2015, 01:01 PM
Carter01's Avatar
Myself and Bader both run this cam. My times in sig, Bader went 8.95.
Old 01-12-2015, 01:03 PM
Carter01's Avatar
-8.75 @ 153.7 - 1.23 - 300shot - 07/14/13 - WhiteLTone - Heads/Cam/Nitrous--FS w/carb
-8.93 @ 150.0 - 1.30 - 300shot - 03/30/13 - Thadd (Hitman) - Heads/Cam/Nitrous -- FS
-8.95 @ 149.2 - 1.20 - 250shot - 10/20/13 - Bader Al-Sharshani - Cam/Nitrous--SS
-9.23 @ 146.0 - 1.25 - 275shot - 02/15/13 - Trans Am Dan - Heads/Cam/Nitrous -- FS
-9.29 @ 140.5 - 1.34 - 300shot - 11/10/11 - ls1guy07 - Heads/cam/Nitrous -- FS
-9.30 @ 144.5 - 1.33 - 150shot - 11/13/10 - 02SS:ZEUS - Heads/Cam/Nitrous -- FS
-9.31 @ 146.1 - 1.37 - 300shot - 05/31/13 - Carter01 - Heads/Cam/Nitrous--SS
Old 01-12-2015, 03:20 PM
krissoto's Avatar
2 bad units right there. Pay attention the these guys and they will get your car rolling.
Old 01-12-2015, 03:28 PM
Would it be out of the question to expect a low 11 very high 10 with a 125-150 shot? On a radial of course
Old 01-12-2015, 05:27 PM
krissoto's Avatar
Anything is possible, do u have all the other supporting mods to go with it. Suspension, gears, anything to support the power u plan on throwing at it.
Old 01-12-2015, 05:58 PM
I have full exhaust still deciding what size stall I should get either a 3600 or 4k. Im gona add u/d pulleys and a cut out aswell. I have 4.10 gears but not to sure if thats the best route maybe 3.42 or 373s would be better
Old 01-12-2015, 06:54 PM
krissoto's Avatar
U still rocking the stock 7.5? Get the car to 60'
Old 01-12-2015, 07:01 PM
Yea still stock
Quick Reply: nitrous with torquer v2 cam
