do i need new fuel jets?
Old 01-11-2015, 04:12 AM
formula218's Avatar
Default do i need new fuel jets?
i'm in the process of swapping a 5.3 into my '94 firebird. i was spraying my LT1 with nitrous and have a set of jets. with my 5.3 i'm using the same Racetronix pump i had with the LT1 but using a C5 fuel regulator. i'm going to need to get new fuel jets, correct?
Old 01-13-2015, 01:45 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
If it is a different type of nitrous system, like going from a nozzle to a plate or vice versa, the jets will be different anyways. Or any change in fuel pressure would require a change in fuel jet size.
LT1's ran somewhere around 43.5 psi, LS stuff runs close to 60 psi factory.
So odds are, yes. You will need different jets!
-Garrett
Old 01-15-2015, 07:29 AM
formula218's Avatar
i think i'm just going to go to a plate setup, with a SLP lid setup there isn't much room for a nozzle between the MAF and TB.
Old 01-15-2015, 08:24 AM
Sounds good! Let me know if you come up with anymore questions.
-Garrett
Old 01-15-2015, 01:48 PM
formula218's Avatar
will do, thank you for your time.
Quick Reply: do i need new fuel jets?
