what times will i get out of my tnt wet kit 100shot?
i have a 01 ta with heads,g5x2 cam all boltons(m6),slicks,12bolt and will be spraying a tnt wet 100 to 150 shot for the first time next week. my car went 11.8's what will the 100 shot give me?? would you also know what the 150 will give?? THANKS, mike c.
Originally Posted by mw01
i got 1 second and 10mph out of a 100 TNT shot on a bolt on car...and that was on street tires
i was running 11.70s on motor and when i sprayed a 150shot NX i spun and still ran a 11.03 but i was able to get 130mph which tells me that i should of been somewhere in the 10s. the reason the TNT and NX kits can gain a full second is because they are rated at the wheels. a 150 TNT shot is comparable to a 200+NOS shot, so yea, you will get a full second or more with the TNT if you hook.
Originally Posted by Turo
how on earth did you get traction? are you an auto? mine looses traction on street tires on the initial hit and every time i shift . all this on gs-d3's, i need some nittos BAD
i spin pretty bad but run consistantly in the 11's @ 119-121...and yes, im an auto
stock everything though...suspension wise and rear end wise but i also can cut 1.91's on these tires (stock converter) and run 12.8's with lid/loudmouth
i have ET streets but didnt do any better on them and they wabble to much on the top end so street tires it is
