Looking at nx proton kit
Like title says I'm wanting to run a nitrous kit on a turbo application. Years ago I had a sniper wet kit on a procharged car that worked great. For simplicity I ended up just spraying the kit dry and it worked out great adjusting the tune to compensate the fuel. My question is if I buy the proton kit can I spray dry like I did with the sniper? I do want a wet kit just in case. Also is there any exploited view of the nx nitrous proton noid box? I'd like to see what I'm buying just to see how it works.
Ls1tech & Truck Sponsor
Absolutely. You can run that system as dry. We also have a dry system for around the same price that includes the upgraded lightning solenoid. The proton box basically just houses the 2 solenoids inside.
Here is a link to that dry system, let me know if you need forum pricing on these items.
http://www.nitrousexpress.com/21000-...lb-bottle.html
Thanks,
Garrett
Thanks,
Garrett
Thanks,
Garrett
Thanks,
Garrett
I really like the longer lines.
Couple more questions. If a solenoid goes bad is it something I can service myself like traditional noids or would I have to send it in to you guys? Do you'll sell replacement solenoids for the proton unit? And are they e85 compatible? Also thanks for the link to the dry but I'm going to stick with wet. Only want to run 50hp for spooling the turbo. Thanks again.
Thanks,
Garrett
Ordered the 20420-10 kit from summit racing. Had a $100 gift card and $25 off coupon I come out like a champ lol. Even ordered a new fire jacket!! My previous fire jacket was a green welding jacket I got free from my work haha.
Think I'm going to push the boost to 14psi and spray the track. 50hp worked great on my procharged setup. 35 hit harder but was barely noticeable in et gains. This new motor is built much stronger so I may push the 75hp to it. My goal is to run this setup into the low 6's maybe high 5's and my best so far is 6.85 so the 50hp may put me in the range I want to be.
Was going to order a transbrake but for the amount of racing I do the nitrous was the better route. My injectors are on the small side for e85 so the wet kit will allow me to keep af's in check. Also my intercooler is on the small side and that was another factor in choosing nitrous over transbrake.
Thanks for all the tech guys!
Right now my base fuel pressure is set to 48psi and add 14psi for 1:1 rise will give me 62psi on the rail. I think it's going to be a bitch to tune for. Any advice on this? This is part of the reason I wanted the option to spray dry.
Awesome! How was the af with the nx jets? Are they jetted on the rich side?
We are on the conservative side out of the box. If you are running nitrous with boost, just make sure you boost reference your fuel pressure for the nitrous system and jet it for your base fuel pressure, 48 psi, and you'll be ready to rock. Normally you want to shoot for at least a point richer than what you are running WOT on motor, when tuning the nitrous system, this varies a little bit with each application and the tuner's preferences.
Thanks,
Garrett
Thanks,
Garrett
Got the kit the other day. Very simple kit they have put together. Only complaints I have is I received a free n2o psi gauge from summit racing and there was no way to hook it up without buying an adapter. The other thing I was not expecting was both noids are wired in together so if I choose to spray it dru I'm going to have to cap off the fuel at the rail. But otherwise great package. Seems it has more length feed line than my previous sniper kit. Thanks again for the tech.
I think I threw my instructions away lol.
My bottle doesn't have any 1/8th npt ports. Maybe different valve perhaps? My wires are just like you said. In the red sleeve there are a blue and black wire and in the black sleeve it is the same, one blue and one black. Do both the wires in the red sleeve hook up to a hot wire? They are different gauge wiring, same for the black sleeve.
Here is a pic of my bottle that came with the kit next to a spare 25 lber i have
