power loss on the juice
Old 03-26-2015, 07:38 PM
M.BOZZ's Avatar
Default power loss on the juice
I now this isn't the correct place too post this but looking for experience. I installed a 4150 plate kit on a ls408 and used a 62 no2 and 28 on fuel, when you full throttle above 3 grand it hits hard at first and then drops off. Its funny because the torque stays up. I'm only doing a 150 shot, any thoughts on this ?
Old 03-26-2015, 08:50 PM
HCI2000SS's Avatar
Do you have a dyno chart you can post?
Old 03-26-2015, 09:01 PM
Old School Heavy
speedtigger's Avatar
Moved this to the nitrous section.
Old 03-27-2015, 08:07 AM
dekan513's Avatar
sounds like u got the jets backwards. u got the fuel jet in the nitrous and nitrous in the fuel. or do u have a progressive controller? bottle pressure staying up?
Old 03-27-2015, 08:08 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Flow restriction, or rich condition, is what it sounds like. Have you checked your filter? What was your bottle pressure before the pull? Also, who's system is it?
Thanks,
Garrett
Old 03-27-2015, 08:58 AM
M.BOZZ's Avatar
Its a nitrous outlet 4150 stinger, tank pressure was at 1000. I'm at the track now and using my cell phone so I'm unable to post the graph. Fuel seemed to may tane at 58 psi, its only a 150 shot and I run a 340 pump so I think that's fine for now
Old 03-27-2015, 09:18 AM
ragtopz28's Avatar
Sounds rich to me....mine did the same thing (one time), I had forgotten to open the bottle.
Old 03-27-2015, 09:34 AM
M.BOZZ's Avatar
Whats up ragtop, lol the bottle was open, I would like to post a graph but don't know to do it from my phone, maybe I will ask my 8 year old to it, lol.
Old 03-27-2015, 09:41 AM
M.BOZZ's Avatar
Maybe bad fill on the bottle, I filled the one and grabbed one from a friend, so I'm at the track now so I'm going to see you it goes. I talked to Brondon @nitrous outlet and I lack a lot of info , thanks guys for the responses. When I get back home I will continue with this
Old 03-27-2015, 11:01 AM
Old School Heavy
I had a local vendor overfill my bottle. The bottle pressure dropped over #200 on the run. I couldnt figure out what was going on at first.
Old 03-27-2015, 11:34 AM
M.BOZZ's Avatar
Thanks speedtiger for moving my thread to the correct place, quicker responses than I thought.. I was looking around the track I'm at to see if someone fills bottles, just dump mine and refill it, but no luck.
Old 03-27-2015, 04:18 PM
M.BOZZ's Avatar
Well I said the hell with it and ran it anyways, off of foot brake and spray out of the hole ran a 10.7 at 127.67 mph.
R/T .416
60 - 1.554
1/8 - 6.9
Mph - 101.45
1000 -
9.007
So I'm happy so far
Old 03-27-2015, 04:23 PM
brandon@nitrousoutlet's Avatar
Were you on a loaded dyno for the pulls you were telling me about? Did you get a pass today on motor?
Old 03-27-2015, 04:54 PM
M.BOZZ's Avatar
The readings I told you about are on a evil mustang dyno. I did not track just motor yet, I will if I can run 1 more time today. Thinking my problem will be with fuel pressure, I was watching the gauge on the rail and did drop down too 25 psi, just in part and doing some wot shots, so its time for a stand alone, hint, hint
Old 03-29-2015, 03:51 PM
M.BOZZ's Avatar
Old 03-29-2015, 04:02 PM
M.BOZZ's Avatar
Not as bad as i thought. Guess im going color blind also.
Old 04-03-2015, 11:48 AM
That 16.0 air/fuel is not a good thing. Is that correct?
Old 04-03-2015, 02:21 PM
M.BOZZ's Avatar
Yes it is, good info earlier brandon. I'm looking into what you told me. Great customer service and thanks again
Old 04-03-2015, 02:41 PM
You're welcome! Let me know how it turns out.
Quick Reply: power loss on the juice
