Need opinions on theses parts
I've taken some nitrous parts in on trades and I'm not sure what to do. I'm thinking about parting it down and just keeping a couple of things to build off of my kit.
What I have and am using is a brand x single nozzle wet kit. -4 feed line and want to be able to run a 200 hit with it. So I'm probably going to upgrade the -3 noid to nozzle lines with -4.
The list of parts I've taken in
90mm TNT power ring 90mm 2 nozzle with 4 lines unknown jets
NOS nitrous noid pn 16045 -6 fitting
NOS fuel noid pn 16060 -4 fittings will fit gm rail 1' long -4 line
-4 feed line 14' long
-6 feed line 14' long
78mm NOS nitrous wet plate w/ .035 and .038 jets
Unknown brand 15lb(?) bottle with pro flow valve and gauge -6 fitting
The listed parts I'm probably going to sell. I'm keeping the -4 lines to replace my -3 lines from the solenoid to the nozzle. Any idea what that stuff would sell for? Or if there's any interest I can email pics.
Ls1tech & Truck Sponsor
Yeah make sure you use one of these..
http://www.nitrousexpress.com/10124-...-hose-end.html
and this fitting..
http://www.nitrousexpress.com/16109-...-straight.html
The -3 line from the solenoid to the nozzle will limit you to 150 hp worth of flow. That bigger line will let you flow 250hp through a single nozzle easily.
As far as value of the other parts, I would do a search on ebay and try to price match some of it.
Let me know if you have anymore questions.
Thanks,
Garrett
and this fitting..
Thanks,
Garrett
