best way to tune fuel for nitrous
Old 04-14-2015, 10:26 PM
Bowtiedford's Avatar
Default best way to tune fuel for nitrous
I have a 2 stage Nitrous Outlet plate and a NX stand alone. I run 55 psi fuel jet settings. I'm wondering how do most guys fine tune the fuel side. Do you adjust a few pounds on the regulator or do you change the jets a few sizes?
Old 04-15-2015, 08:16 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Either way is sufficient. For me its easier to go down a couple jet sizes than reflow the regulator, but on a tight clearance direct port that may not be the case.
Thanks,
Garrett
Old 04-15-2015, 03:07 PM
thanks, thats what I thought. Now just to figure some percentages lol
Old 04-15-2015, 03:11 PM
brandon@nitrousoutlet's Avatar
It really depends on how big of a swing you need to make. I like to change jets to get close and then fine tune with the regulator. Will that regulator go down to low pressure? Are you flowing it through a flow tool? Give me a shout and I can help you with some close starting tune ups.
Old 04-15-2015, 03:16 PM
I can swap out springs for low pressure but I have it set real close now so I'm going to swap a few jet sizes and then maybe take out a few pnds on the regulator. I dont run a lot of nitrous just 100-150 1st hit and then 50-100 second hit.
Quick Reply: best way to tune fuel for nitrous
