Nitrous Outlet jetting inconsistencies?
First kit would hit fine (200) and would end the run in the 10s. Second kit would hit and be way rich. (100)
The graph for the second kit pulls were wavy and way down on power. It's definitely a rich condition.
Im on a standalone with C16 btw.
Right on. Just pull some fuel out of it and it will be good to go. Don't be surprised when its a good bit down from recommended jetting. Each motor is different and you have to give it what it wants regardless of what a jetting chart says. Its what the time slip and spark plug say that matters.
Air/fuel ratios are normally in the range stated.
My buddies lt1 with there plate kit with there old jetting was pegging out the wideband at 10.0 afr. Now with there new jetting it's just a tad rich but the car picked up quite a bit of et with the new jetting chart
