NGK spark plugs revealed (with part numbers and stock numbers)
Old 06-04-2004, 12:06 AM
mbaskett's Avatar
Default NGK spark plugs revealed (with part numbers and stock numbers)
Mod's I put this in the N2O forum only because I was doing this research in order to find the options of plugs for various power/spray levels. If you think it's best in another forum, please feel free to move it as you see fit. Thanks...
Did some research today at the local auto parts store here in Keller. They were kind enough to let me thumb through the NGK catalogs for a good half-hour. Here's what I found for the LS1's
The plug design is as follows:
14mm
.708" Reach
5/8" Hex
Loose - Tapered Seat
Non-Resistor
Code:
Part #        Stock #
TR5           2238
TR55          3951
TR6           4177
BP7EFS        3526
R5724-8       7317
R5724-9       7891
R5724-10      7993
Each one is one heat range colder (except the TR5/55, they are the same heat range) as you go down the list. The last three are considered racing application plugs, and may cause RFI issues with electronics, specifically stereo systems. Below the TR6's is what everyone would reference as TR7, TR8, TR9, and TR10 plugs, although NGK does NOT use these designations in their part numbers.... so you'll probably get some crazy looks if you ask a store for a set of TR7's
Hope this helps clear up some of the confusions when you have to go get spark plugs..... This info was pulled directly from NGK's 2003 Catalog. I can only assume it's correct.
mbaskett is offline
The following users liked this post:
GregM784 (05-25-2021)
Old 06-08-2004, 01:31 PM
Vents's Avatar
good job Bisqcotti!
now i can get tr8's for CHEEP hehe......
Vents is offline
Old 06-09-2004, 03:07 PM
mbaskett's Avatar
Thanks man! Yeah, my local O-Reillys can get all the plugs listed above for $1.49 + tax each.... ends up being $1.61/plug...
mbaskett is offline
Old 06-10-2004, 04:19 PM
VIl
VIl's Avatar
Try to use nitrous oxide catalyser sparkplugs. It will gives up to 1/3 of additional power (from nitrous addition)...
VIl is offline
oldngray (05-26-2021)
Old 06-10-2004, 04:41 PM
The Bull
DERTY's Avatar
Those look familiar. I have to look around but there is a cross reference spreadsheet running around that has every spark plug heat range and make listed. Might be nice so that people can figure out what plugs to jump to if you're going to try out another one.
DERTY is offline
Old 09-22-2004, 09:04 PM
FastBlackTA's Avatar
ttt - anybody out there have this spreadsheet lying around...would be a HUGE help!
FastBlackTA is offline
Old 09-23-2004, 07:28 AM
Tim98TA's Avatar
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
Donate some to me and I'll try them. Heat range similar to the TR8 please.
Tim98TA is offline
Old 12-08-2004, 06:29 PM
tonyt123blue's Avatar
thanks
tonyt123blue is offline
Old 05-25-2021, 02:38 PM
GregM784's Avatar
Great info! Thank you so much for posting
GregM784 is offline
Old 05-25-2021, 02:50 PM
Received 3,021 Likes on 2,352 Posts
It might be OLD INFO. You replied to a 17 year old thread
G Atsma is offline
Old 05-25-2021, 02:59 PM
GregM784's Avatar
Plug numbers are still correct.
I'm still grateful for the OP sharing this info.
GregM784 is offline
Old 05-25-2021, 04:30 PM
Parts and part #s are replaced all the time.
If you knew they were correct it means you have a modern info source, making this redundant.
G Atsma is offline
Old 05-25-2021, 04:32 PM
GregM784's Avatar
GregM784 is offline
Old 05-25-2021, 04:35 PM
Uhh, yeah.... The fact you were able confirm them proves my point.
I fail to see yours.
G Atsma is offline
Old 08-15-2021, 06:41 PM
LazyNoob's Avatar
Hey Man, thanks for your update to the old post. It really helped me.
Cheers,
LS1!
LazyNoob is offline
Old 08-15-2021, 08:40 PM
Cheers,
LS1!
Nothing was updated, all info in this thread is 17 years old.
G Atsma is offline
Old 08-22-2021, 11:26 AM
9 Second Club/Nitrous Mod
shortdog's Avatar
Correct plug info for nitrous applications are in the sticky above: Too much Advertising, Not enough Tech - Spark Plug Reference - LS1TECH - Camaro and Firebird Forum Discussion
shortdog is offline
Quick Reply: NGK spark plugs revealed (with part numbers and stock numbers)
