what fuel to use in a standalone w/ spray?
Wanting to run race gas in my standalone fuel cell on spray. What is everyone using? Ill probably go with Renegade blend cause I can get a good deal on it. Thanks for any input
fuel
Renegade PRO 120 NOS is what I use ,I know it's over kill, but it has additives in to help lube the top end of the motor , i went from the 110 off road leaded to this and was able to add some timing back in a made 35 more hp on the same shot ,
Ill check into that. You can always add a top lube but we have found in our alcohol trucks it will make a pasty while dust and stop up filters and jets. It may not do it in gas. What does that stuff cost per 5 Gal?
Last I bought thinking it was bout 14.00 dollars a gallon , it last a long time in a stand alone
