NX Proton Kit wiring question
Ok I got everything just about hooked up on the kit. My question is....on the instructions it shows the relay wiring with white/green/black/red wires, BUT on the actual relay from the kit, it has an additional blue wire. Where does that blue wire go?
I was assuming since it wasn't being used I would ground it, but once I touched a ground connection, a small spark happened. So I tested the blue wire and it was hot (live wire)? Would I hook it up to a positive connection or just bundle/tape it up and not use it at all?
Also, I have my arming switch near my center console, and I have the 12v/ground/WOT wires all connected right. But when I flip the switch the red light doesn't light up? I tested the ground and 12v and everything is getting the right connection. My brothers switch did the same thing on his kit, is this a bad batch of arming switch? He changed his to one from AutoZone and it lit right up after switching it.
Thanks for any input!!
Ls1tech & Truck Sponsor
You don't have to worry about using the blue wire on the relay. That wire is used for applications with a trans-brake. Also sometimes those lights go out in the switches for no reason but still work as far as activation etc... If you PM me your address i'll get a new switch out headed your way.
-Chris
-Chris
