RWHP on spray question??
I have a quick stupid question. I know most nitrous systems are rated at the wheels. But is that from your peak motor horse power or from the power you make with your timing pulled?
For example: if you make 400rwhp with full timing and 380rwhp with 8 degrees of timing pulled and you spray a 200 shot should 580rwhp be a normal number? Or should it make 200rwhp more from the power you make with full timing in?
Ls1tech & Truck Sponsor
It is almost a combo of both... Factory LS cars can spray 100hp on the factory tunes and 9 out of 10 times they make the 100rwhp more than factory. On the larger shots with timing pulled you should make within at least 10hp of the jetting horsepower, but all of this does depend on the tune up on the vehicle.... If tuned to 10.0AFR then there is no way your making the power. Where as something tuned at 11.8-12.0 should make the power.
-Chris
-Chris
-Chris
-Chris
i've read that a dyno doesnt put as much heat in the cylinders as being on the track, so a track tune would be best, especially if you already have a solid tune on the car.
i'm still learning and reading, so dont take it the wrong way still trying to figure it all out.
I like to tune about half a point richer than WOT N/A AFR. Normally around 12.0-12.5.
Pull the timing from where the motor makes its most power N/A. There will be a slight powerloss N/A with the timing pulled, and a properly tuned nitrous system should make pretty close the the HP rating if tuned up correctly.
On higher horsepower applications, such as a 300 shot, there is more that goes into it and many different variables that will determine how much power a motor will make. (Timing, AFR, Cam specs can either help or hurt power on nitrous at higher horsepower levels, as well as the rest of the drive train, transmission, etc.) These are general ratings, but if tuned up correctly, they should make pretty close to the HP rating, to the wheels.
Thanks,
Garrett
Thanks,
Garrett
