MSD window switch ?'s
i know that this has been beat to death, but i've search on this and i'm still confused!!!
how EXACTLY do i need to wire my MSD window switch on my '02. i mainly need to know where the yellow wire connects to the FPSS
i've got the NX wet kit with the GenX-2 accessory kit.
anyone wanna cover this again for me?
thanks
mac
thanks
mac
well first need to cut the loops like it was for a four cylinder to work with the ls1, then put white wire to tach #10pin, then red to 12volt, black to a ground, and the yellow goes to one the fpss on one side and the other side of fpss goes to white wire on relay or if you dont use the fpss the yellow wire goes to the white wire on the relay, hope this helps
On my setup I have the yellow wire going to one side of the FPSS (doesnt matter which side) the the other side of the FPSS connects to the **Edit**negitive wire(Green) on the relay.**Edit**
Just drew this up kinda quick, hope it helps.
-William
-William
Originally Posted by SSDriver
On my setup I have the yellow wire going to one side of the FPSS (doesnt matter which side) the the other side of the FPSS connects to the negitive wire(doesnt matter which wire) on my solinoids. Works great for me.
-William
-William
you CANNOT use a MSD window switch provide the ground for a solenoid, it can only support .5 amps, and MUST drive a relay.
Ryan.
ok sorry to bring up a dead post just i've been seeing different answers through the lists. The FPSS gets connected by the MSD window switches yellow wire on one end and the NX relay's white wire goes to the other end and is that it or do I have to still connect one end to the body of the car for a ground or is that what the yellow wire for the window switch is for?
