More nitrous , same et, less mph? !?!
So my car went 10.1 at 135 on a 150 shot. Then went 10.1 on a 300 shot at 130. Tune adjusted accordingly, timing, and fueling. Why more nitrous and same et? Only thing I changed was a plate to a puck, and from a victor jr to a super victor.
I think I need a bigger cam. 6.0 243 heads forged bottom end. Not sure specs on cam
Never ran on hp. Reading plugs for timing and afr. Also using a wideband. Here is what is funny. I'm jetting 99 and I think the low psi system calls for a 78 jet ? Not sure off hand but, I had to jet it down to a 46 on the fuel side, way less than what is called for for jets
my guess is converter cant take it or trans. dual it down with the progressive where it dont hit so hard and see if mph picks up. but if ur having to jet ur fuel down that much sounds like flow problem on the nitrous side.
