spark plug recommendation
I have SBE, TV2 cam, 241 heads home ported with no milling, so stock compression. Right now I have 2 x .053 or approximately 200 shot on 93 pump fuel with 18 degrees total timing. Best is 6.55 @105 and 10.28 @129. Can't even see a timing mark, just burns the coating on the NGK plugs.
I have been running B8efs but wondering if Br7efs would be okay.
Opinions?
Opinions?
For 200 you're right there on the border of the 7 and 8 range plugs. It sounds like the 8's may be too cold from the way you're describing, so move to a 7 and see if you have an improvement.
