427 ls3
427 ls3
How much power can a LS3 block handle? I wana put tfs245 with n20 port by btr and btr cam. 105Mm Holley hi ran with 2in headers 13:1cr on e85 should I to solid roller or stay hydraulic with short travel lifters. I wana spray 300-350 on this setup. And is their a iron block 6.0 that will to 4.070 bore safe?
I wouldnt get too greedy with nitrous on that application. The main issue is with a 427 on a small bore you end up running a 4.125 crank and the result is a thinner crown on the piston.
