Any alternatives to the NX Octane Gauge / Progressive Controller?
Anyone know of any products comparable to the oldschool NX Octane Gauge?
On paper it looks awesome-
Pressure gauge
Bottle level gauge
AFR safety cutoff
etc
It looks like it was out for a bit around 2010 but not listed anywhere on NX's site.. so I'm assuming it was discontinued.
Anything else out there comparable? The closest I can find would be the Innovate PSN-1 and then a progressive controller like the Maximizer 4.
Pressure gauge
Bottle level gauge
AFR safety cutoff
etc
The NOS Launcher has all of the same functions and is available with a touchscreen. However; it's not the type that would fit in a gauge pod, and it doesn't have the % full of the bottle. Also, you'd have to separately purchase the harness for bottle pressure, and the wideband box to enable the rich/lean cutoff features. It does offer real-time monitoring as well as data logging. BUT..Holley has been out of these for some time and the date keeps getting pushed back as to when they will be available again.
Innovate makes a 2 1/16 that does most of that
PSN-1: PowerSafe Nitrous Bottle Pressure & Wideband Air/Fuel Ratio Gauge
The PowerSafe gauges combine our patented DirectDigital™ O2 sensor control technology with application specific sensors, an OLED display, and a smart safety override circuit for your high performance vehicle. Our PowerSafe technology can disable your factory or aftermarket boost control solenoid forcing the system to spring pressure. In nitrous applications, our PowerSafe technology will disable your nitrous solenoid to keep your engine safe. The PowerSafe gauges offer the looks, safety and performance enthusiast’s demand!
All-in-one, Nitrous safety overide and wideband air/fuel ratio gauge w/RPM window switch
52mm (2 1/6”) diameter gauge body
Interchangeable faceplates and bezels: Black and silver bezel, black and white faceplates included
No PC required for configuration
OLED user configurable display
Nitrous Bottle Press., shift light, Air/Fuel ratio
AFR or Lambda, inHG, PSI, kPa, or BAR
1500 PSI nitrous bottle pressure sensor
User programmable nitrous safety cut using Air/Fuel ratio and bottle pressure references
Nitrous cut by lean air/fuel condition
Nitrous cut by minimum bottle pressure
User programmable RPM window swtich range, 10 RPM increments
30A Relay included
Patented DirectDigital™ wideband sensor control, the only 100% digital wideband air/fuel ratio technology!
Wideband O2 Compatible with several fuel types (Leaded, Unleaded, Diesel, E85 & more)
Ability to calibrate O2 sensor for maximum accuracy
Configurable linear 0-5v analog output for wideband O2 for use with piggy back or stand alone ECU’s as well as external data loggers
Innovate MTS serial in/out (for use with other Innovate & 3rd party MTS enabled devices to add additional logging channels)
4 channels of log-able data with powerful LogWorks PC Software (MAP, RPM, A/F, Nitrous solenoid active)
http://www.innovatemotorsports.com/products/psn1.php
Been thinking of getting it, will see how I like their DLG-1 dual wide band gauge
30A Relay included
