Fast 92mm plate kit
Fast 92mm plate kit
I have a fast 92mm intake I'm wanting to buy a 150 shot wet plate kit I'm looking at the nitrous express plate kit but they only offer a 90mm plate should I use a 90mm throttle body with the 90mm plate or will a 92mm throttle body be okay on a 90mm plate? I was just curious if the difference in size would cause some drag or turbulence in the intake tract. Thanks for the advise in advance
I am trying to keep all lines and solenoids off of my intake manifold, that's why I was leaning towards nitrous express, and mounting all solenoids off the passenger side head and running them into the passenger side of the plate , I'm just trying to keep this neat and clean I was just worried that the 90mm plate would hurt performance on my 92mm throttle body but it doesn't sound like its going to be noticeable difference
Ls1tech & Truck Sponsor
Our 90mm plate actually measures out just slightly larger than 90mm so you will be just fine using our plate on the 92mm intake. Also we can make custom length hoses to make sure you get the look you're looking for. Just give me a shout and I'll make sure to get you covered.
-Chris
-Chris
