Questions about my setup need advice
2000 camaro a4 with forged lq4 ls6,heads nitrous spec cam, 340 stealth in tank pump. I want to run a 250 shot for now off the stock rail. If put a boosta pump on toggle switch to use only when spraying will that be enough to keep me from going lean on initial hit. All info is appreciated
I too would advise against a 250 shot off the rail. You need a stand alone setup once you step up to that big a shot. Do you have any experience at all running nitrous? I would advise you take baby steps and learn how to read plugs and adjust the tune-up accordingly.
Yes I've ran nitrous plenty of times and I know reading the plugs is the best way to tune I was just wondering about the stock rail and it looks like there will be a nitrous dedicated fuel system in my future haha. I was planning on that route when I up the shot even more but I was hoping to slip by for a while at 200 or 250 for now but that's doesn't seem to be an option.
