250 shot on stinger (PLUGS???)
Just got my stinger kit and dedicated fuel system in. (AWESOME QUALITY PRODUCT!!!!!) Thanks Scott and AJ. What NGK plugs would be a good starting point for dyno tuning? I am going to start with a 150 then to 200 and onto 250. I was figuring starting at a 9 but Im looking for advice from the pros.
Thanks
Thanks
I honestly do not have a good answer for that. I was concerned about the running leaded fuel but learned today that Q16 is leaded as well. I am still researching what the best fuel will be to use that will allow me to keep the most amount of timing in the car. Any help is appreciated.
At 150 I'd start at pulling 6 then working from there. I run 30 degrees total with 91 pump gas and C16 in the stand alone My combo on 150 ran best with 6 out even with c16 in standalone.
I have always used -9s for 150-175 and anything above that I use -10's.
Old SBE motor and new motor.
For timing I would pull 9-10 and bring it back in, as you make passes and read plugs.
it's easier to put timing in than pistons.
JMHO.
JMHO.
I run 7s on a 200 shot with c16. Seems to be pretty happy with that
Will C16 have any bad effects on my wideband O2? Other than that, this is all very helpful. I am hoping with a really good chassis setup that she is capable of a 8.99. I just need to squeeze every little bit out of her. In good cold weather I am expecting 10.4's maybe 10.3's N/A.
Yes you are correct. I run 93 in the tank and I guess I'll be running C16 in the dedicated. Thanks for all the help. I'm doing the install today and hope to have it on the dyno by the end of the week and at the track by the weekend.
Very much appreciated.
