Normal to have 25-50psi drop?
I have my guage on the line, right past the valve, so when I crack it and close it, I can see the "line" pressure lose 25-50psi and then stop.
So I will crack the valve and close it, and the line pressure will go from 950 to about 925 and stay there.
First thought is a leak, but the fact that it steadies out has me thinking it may be expansion of the line?
Anyone ever seen this?
If the line in front of the valve isn't pressurized when you open the valve you can expect a slight pressure drop from it having to fill the volume of the empty line. If the line is already pressurized and it drops when you open the valve you may still have a small leak somewhere. If that's the case- use some soapy water in a spray bottle to try and track it down.
