Dual stage vs progressive
Old 11-29-2015, 09:00 PM
98redorangeta's Avatar
Default Dual stage vs progressive
What are the limitations of each? Is one better for a big shot vs a smaller shot?
I am mostly concerned with guys trying to keep 10 bolts alive on autos with under 200 shots. So if traction isn't the only motivation does that change things?
Old 11-30-2015, 04:29 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
My personal preference is a single stage w/ progressive setup. I feel that you have more control over the system that way. Also when changing the progressive ramp you don't have to adjust the tune as you would when running 2 complete stages.
-Chris
Old 11-30-2015, 09:15 PM
Bowtiedford's Avatar
I like the 2 stage, but I use it right out of the hole, and then if needed to play catchup I use the 2nd stage. I usually use 150 first and then 100 second stage. I like the control better when I have to hit it and then possible let up and then rehit it again.
Old 12-01-2015, 09:36 PM
Bow tie do you have both on a push button or do you have controller hooked to both stages?
Old 12-01-2015, 09:44 PM
my setup is a little different then most, I use a hand held push button for the 1st stage and a foot switch for the second. My car is setup for a sleeper look.
Quick Reply: Dual stage vs progressive
