Pulling off the rail (How big can I go)
Old 11-30-2015, 08:56 AM
MFJ
MFJ's Avatar
Default Pulling off the rail (How big can I go)
I've finally got the new motor combo tuned correctly (that was a nightmare). Ended up doing a SD tune on it. Anyway, it's safe to spray it now. So here's my question.
How big of a shot can I spray pulling off the rail? My 42lb injectors are at 75% duty cycle now on motor at WOT. LS3 rail and LS3 injectors, racetronix 255lph with the hotwire kit. I'd ideally like to spray a 200 shot but I'm thinking I might run into fueling issues.
It's just a little 346 stock block LS6.
Old 11-30-2015, 10:48 AM
HCI2000SS's Avatar
You might run out of pump before you max the rails
Old 11-30-2015, 12:30 PM
MFJ
MFJ's Avatar
That's what I was thinking too. Maybe time for a stand alone system? I think I can pull enough for a 100 shot of the rail but I built the motor for a 250 shot.
Old 11-30-2015, 05:11 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
The 255 w/ hotwire should cover you for around 650-680rwhp. If you think you're going to be close to that or over that power then I would look into getting a dedicated.
-Chris
Old 12-01-2015, 06:53 AM
MFJ
MFJ's Avatar
Yep. That's what I was figuring too. I'm going to be well over that at the rear tires. It's a shame they cost an arm and a leg. At least for a good one. Carbureted motors are so much cheaper to do.
Old 12-01-2015, 08:27 AM
Squirts11's Avatar
What are the limits of the rails? Why not add another in-tank pump? Another 255 would be much cheaper than a standalone, plus would raise the cap on your potential power to be made.
Would you need to run new lines and a regulator up front by simply adding an additional pump?
Quick Reply: Pulling off the rail (How big can I go)
