Nitrous + Meth + Procharger = FTW!!
Nitrous and Meth injection make a good combo on a procharged C7!!
4 Solenoid Direct Port w/ Rail upgrade and a Hardlined Methanol Direct Port
If you have any questions about the setup feel free to give us a call 940-767-7694
-Chris
-Chris
The customer ended up making over 1000rwhp on the setup. That was with 100hp shot on the DP I believe.
Are you wanting to fuel the setup with meth or are you talking about spraying and using the meth as a supplement to help with detonation issues.
-Chris
-Chris
I have a separate snow performance meth kit. I run 93 with the meth coming on around 8psi. I want to add a 100 shot to help spool up. so I'm thinking of pulling fuel for the nitrous from the 1.1 regulator using 93. How would that do?
But I'm also worried if I spray for a complete pass that the rising fuel pressure from the base of 58psi might throw off the nitrous jetting and basicly go rich on jetting. whats your thoughts on that?
