So many diagrams!! NOS MINI and LCM-2000
Old 04-17-2016, 02:33 PM
efuehrin's Avatar
Default So many diagrams!! NOS MINI and LCM-2000
I've been searching for weeks now and everytime I find something different.
Some have the + for the solenoids going through the relay some have the solenoid + straight to batt.
Some have the Throttle Pos Sensor wired to the MINI controller WHT/BLU wire, some to the 85* on the relay.
Ahhah!
I'm using the MINI controller with a wet plate system and I want to use the LCM-2000 to pull timing only when my NOS is activated. That's all I have. No linelock, no opener, no heater.
If you can help it would be much appreciated but if not I under stand too.
Here is the diagram I have so far that seems to be the best fit.
Old 04-17-2016, 02:36 PM
efuehrin's Avatar
Also the TPS above is that a micro switch or a tap off the Throttle Position sensor? I'm guess it's a switch because the sensor only puts off 0-5V or 5-0V I thought.
Old 04-17-2016, 03:11 PM
efuehrin's Avatar
After some more research I think all I need is this.... Thoughts? It won't give me the two step but will pull timing.
Old 04-18-2016, 08:19 PM
jblankenship's Avatar
Why not just use the aux output on the mini? Then if you delay the nitrous you can delay timing being pulled.
Quick Reply: So many diagrams!! NOS MINI and LCM-2000
