Z06 on Direct port. Timing Retard questions
I have a built LS7 that has diamond pistons, heads, cam, MSD intake with NX direct port spraying a 200 shot.. I am running the maximizer 4 and a LNC2000.. The car HP was low on the dyno, made 160 rwhp from the 200 shot. We were very conservitive on timing. As of the last pull we had 11* being pulled by the LNC2000. I am running c16 fuel in a stand alone cell for the nitrous. I would think I should have picked up a bit more off a 200 shot. Should I do some pulls on street and add a degree and check plugs after every pull? Thanks in advance.
No we did not. It was a super late night on the dyno due to issues with another vehicle. We got the NA tune done and adjusted timing and afr for nitrous on a few dyno pulls and called it a night. The 160 hp seems low off a 200 shot. I think there is 24* advanced on NA tune and I'm pulling 11* with the LNC2000.
Good luck! Go out there and make a pass, put a degree of timing into it and if it picks up mph, it needed timing. Repeat until it stops picking up mph then back it off a degree. Take plenty of plugs! Fresh set to find the hottest cylinder and then you can stick to checking that hole.
