Ls 6.0 iron block 150 shot
Old 04-22-2016, 09:44 PM
Ghostx3's Avatar
Default Ls 6.0 iron block 150 shot
I'm doing engine rebuild I'm on the process off buying pistons now for all the experience guys what you think on the compression. Which would work better for daily driver. I wanna keep stock rods. And I'm just going for around 500whp
Wiseco K398X05 -3cc 4.005 with stock ls3 heads I'm looking around 10.3 compression
another piston the I was looking at will be. +9 wiseco 4.030 it will come out at 11.3 compression
I wanna do a 150 nitrous shot
Any help will be appreciated. Thanks.
Old 04-22-2016, 10:52 PM
ATwelveSec02Z28's Avatar
i wouldn't worry so much about compression.... There are other factors way more important such as ring package and placement, alloy, and overall design.
You want a lowered first ring land, good alloy, a smoothed piston top. Gas porting is great as it will help ring seal.....
Compression can be handled through cam design to make it tolerable
Old 04-23-2016, 07:14 AM
Bowtiedford's Avatar
all the info posted above. I've liked a flat top style piston for a better burn area or should say quench area.
Old 04-24-2016, 01:17 PM
87silverbullet's Avatar
With just a 150 shot, I don't think much of that is really going to matter. With that said, I'd shoot for the 11.3:1 compression piston.
Old 04-26-2016, 11:25 AM
I will politely disagree with this....
all of the things I mentioned will make the engine more efficient on nitrous.
Static compression ratio is pretty ranging too.... you can get vastly different nitrous characteristics all based on dynamic compression.
Old 04-27-2016, 05:20 PM
On more nitrous, i would agree. On a 150 shot you will not seeva noticeable improvement.
Old 04-27-2016, 09:20 PM
99FRC's Avatar
yeah, but who builds a forged motor and stays on a 150 shot? Better to build the motor right for a larger shot later.
Old 04-30-2016, 05:23 PM
1970camaroRS's Avatar
Exactly, because you know that's what's going to happen. 150 worked good...why not 200...250...300...
Old 04-30-2016, 05:34 PM
I'm going forged once I start going pass 300
Old 09-01-2022, 08:35 PM
In-Zane Moderator
ZONES89RS's Avatar
And if you want 600 HP+, throw some dome pistons from summit in there. 11.5:1 with a cam and square ports? As long as the intake is decent that’s easy 600 HP
Old 09-07-2022, 11:44 PM
ovaboost's Avatar
Do 10.3 or 10.5 so your tuning window isn't small 11.1 and up you'll want race gas mixed with pump for detonation reasons
Old 09-12-2022, 12:08 PM
grubinski's Avatar
I’ll beat GAtma to it … this thread is 6 years old 🙂
Old 09-12-2022, 12:59 PM
Received 3,021 Likes on 2,352 Posts
Originally Posted by grubinski
I’ll beat G Atsma to it … this thread is 6 years old 🙂
Too late, TWO guys responded.... it's on a roll now.... LOL
Quick Reply: Ls 6.0 iron block 150 shot
