How do I install timing tuner on NX N2O
Originally Posted by Pro Mouse
Ok does any one have any pictures of where your timming tuner is wired into?I dont understand how to wire it up to the n2o system?I am no electrical engineer by any means
Thanks!!!
Scott
Thanks!!!
Scott
Grey wire goes to the same relay, on the negative (ground) side in the same fashion....
I guess it supplies and takes away the ground/positive to the solenoids after the relay but before the actual wiring to the solenoids....
hope it works!
the white wire gets spliced into the positive lead on the soleniod relay. The gray wire grounds the solenoid relay and gets connected directly to the relay. The other connector plug plugs into the crankshaft position sensor located behind the starter. You may have to drop the starter and headers to install the plug.
Originally Posted by 1jfuddle
How can you tell if it is pulling timing at WOT???
I am diong the install on mine and I am leery of just trusting it.
All I can tell you is that it works.
Originally Posted by BMN
From what I've read, it should be pulling timming whenever the unit is turned on.
Just remember when hooking this box up that your nitrous relay only grounds to the Timing Tuner and not the Timing Tuner and another ground. The power wire is the one that goes to more than one source.
Jamnut is correct,I did NOT think mine was working either because A-Tap was NOT showing the Timing being pulled out!So I disconected the fuel power and and with the bottle valve Turned OFF ,I set the RTD at 15 of timing to be pulled out,I turned on the n2o arming switch and let it Rip!It must be working ,man the thing was a pig,the I turned off the n2o arming switch and let it rip,my power was back.So my timing tuner must be working
So did I just fry mine???
I just hooked it up by splicing it into the ground instead of using it as the ground. When I hook it up AS the ground, it wont click the solenoids. What should I try next???
Glad to hear you didnt fry it!It is tricky to hook up....
