Looking to see if this is good combo for nitrous
i have prc 5.3 heads and ms3 cam with a 150 shot I just ordered 410s do you guys think these gears will be okay with the spray and please only people with experience post car is m6 on a full slick 28 car made 550/600 thanks guys !!!
If you look at my signature you will see that I basically run this exact combination of parts that you listed. With that said the 4.10's are perfect n/a, but on the 150 they are too much IMO. I run NTO5R's and can't get traction until 3rd gear. You running slicks should help
If you can't get traction on a 28" slick with 550hp giving it everything off the line you have either some suspension issues to work out or a slippery track. Mine went 1.6 on a soft 10 bolt launch on my 6 speed with a 4k quick slip of the clutch on a 275/50/15 et radial at about 500whp.
On motor I use to blow away my 275/40/17 nt05r tires. They were probably the worst drag radial I've ever used.
