Nx or Nitrous Outlet
Old 07-08-2016, 11:07 AM
joe1998ls1's Avatar
Question Nx or Nitrous Outlet
found a deal for a nitrous express kit intalled plus tune for around 1400....i guess thats a deal...i know the nitrous outlet set up alone will be around 1200...which system works the best for the money??
Old 07-08-2016, 11:10 AM
HCI2000SS's Avatar
What does the NX kit include? I run NX as well and an very happy, but from what I hear Nitrous Outlet is just as good
Old 07-08-2016, 11:19 AM
joe1998ls1's Avatar
well im not sure he said the kit was around $900..i was looking on their site for a kit around that price range but i couldnt really find it...nitrous outlet's site makes it easier to find
Old 07-08-2016, 11:24 AM
HCI2000SS's Avatar
If thats true then $1400 is great deal for install and tune
Old 07-08-2016, 11:33 AM
Rise of the Phoenix's Avatar
Either company will take good care of you. I assume you're wanting something like a plate kit?
Old 07-08-2016, 12:37 PM
AJatNitrousOutlet's Avatar
What kind of kit are you looking to do?
Old 07-08-2016, 01:48 PM
joe1998ls1's Avatar
I plan on doing a plate kit with a 150 shot to see how it will work with my btr stage 4 cam
Old 07-08-2016, 01:52 PM
Alright, what intake manifold and TB combo are you running? Are you needing any accessories with it? You can PM or call me if you like-
Old 07-08-2016, 03:05 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
That's not a bad deal at all on the system - install - and tune. Any questions or concerns that you might have feel free to give me a holla here at the shop.
-Chris
Old 07-08-2016, 03:25 PM
joe1998ls1's Avatar
i have a ls6 intake with a ported tb...and im running the white gxp injectors with and aeromotive 340 fuel pump
Old 07-08-2016, 04:13 PM
Nice choice on intakes! What all accessories are you wanting to pick up on it? Purge, bottle heater, window switch, timing retard, etc?
Old 07-08-2016, 04:28 PM
joe1998ls1's Avatar
Just a bottle heater, purge and the console switches
Old 07-08-2016, 04:30 PM
HCI2000SS's Avatar
You definitely want to pull some timing on that 150 shot
Old 07-08-2016, 05:24 PM
joe1998ls1's Avatar
Yea the gut at the shop where it is now was telling me about a box to pull timing out of it...but I think I'll take it to another shop to have the system put on it seeing that my car has been there for a year now.....ridiculous
Old 07-08-2016, 05:47 PM
joe1998ls1's Avatar
HCI2000SS....do you think I can get in the high 10's with this set up it has some stock 799 heads. ..a4 3600 converter
Old 07-08-2016, 05:49 PM
HCI2000SS's Avatar
Sure. With the 150 shot and some good traction definitely
Old 07-08-2016, 06:09 PM
joe1998ls1's Avatar
We shall see if I ever get it back lol
Old 07-08-2016, 09:04 PM
5.7stroker's Avatar
Are you going to run a NOS Mini and LNC-2000 or similar? Those are most likely the "box" that that they are referring to.
Check this link out here for my install:
https://ls1tech.com/forums/nitrous-o...tall-pics.html
Where are you going to mount the bottle? If you mount it in the passenger side spare tire well using a bracket kit, the fixed blow down tube won't work because it's too short. You need a 2.5 foot 8AN line with a 180 degree fitting on one end, and a 8AN female fitting on the other to connect to a 8AN bulkhead fitting. Something like a Fragola 483108-BL bulk head fitting or similar. Just drill a 3/4 for the bulk head fitting.
Old 07-09-2016, 07:15 AM
Blazeracer's Avatar
Flip a coin. Neither is a bad choice. They both kick ***. I run a NO plate cause I got a great deal on one used, but would have run a NX plate just as well.
Old 07-09-2016, 09:12 PM
joe1998ls1's Avatar
Ok thanks for the feed back
Quick Reply: Nx or Nitrous Outlet
