Brand x any good?
How do they like to be pulsed? Planning on running a progressive and I'm curious if anyone knows what frequency they "like" and if they hold up well to being progressed
Back EMF Reading
My method is to test the actuator.
I would "bench" test using nitrogen or C0-2, pulse the valve, very the frequency, read the EMF with a scope.
This is a very easy process, if you want my help, just ask.
Lance
Lance
How many guys do you know that have an oscilloscope laying around?
I have access to one, but getting real world experience from guys that have run them, who have had them last (or not) is invaluable (and also what I asked for)
Good morning, You will actually want to start off our solenoids at 20hz. This is a good setting when it comes to progressing the solenoid. (If you had a trash can solenoid you would start off at 15hz due to the size and weight of the piston to allow the solenoid enough time to react.) Our X-series system solenoids will be able to handle the task of a 150 shot no problem. Max flow on our x-series solenoids are 200hp. Feel free to contact me if you have any questions. - Houston houston@nitrousoutlet.com
