LY6 Silverado Swap...WHAT NEXT
Greeting LS1Tech peeps! New member here and figured I would ask some of you pros out there on a question I have for a little power adder Im in the market of purchasing for my truck.
Starting off I removed my old LM7 and swapped it with a midly built LY6.
The LY6 has had the L92 heads worked (milled .020) with all new springs, trunion upgrade etc.
The bottom end has had minor factory crank work, factory rods, flat topped pistons, cast iron block has been bored .030, and a 3 bolt cam (.615/.620 110lsa) and a few other little things.
My question to everybody with knowledgable input is I am in the market for a nitrous kit, now bare with me as I am new to the whole situation, but I am stuck on which kit would work for my setup and can a kit work with it. Ive seen a few with direct injection and throttle body plate. Which is better within a reasonable price? Any input would be welcomed and if I am poster #793,038 please stear me in the right direction of a similar post!
Thank you in advance to any help given!
What intake and throttle body are you currently running? What are your goals for the truck? How fast do you want it? I chose Nitrous Outlet for all of my components and have been very pleased with them.
But I have the factory L92 truck intake (tall) with a NW Billet 92mm TB. Basically if I run somebody at WOT i want to at least have a good gap, or in this case if I run my buddy he cant keep saying "but mines stock" with him staying right behind me lol.
For your goals I would suggest calling Nitrous Outlet and getting them to hook you up with a single nozzle kit. It is a single direct port style nozzle that will mount in your intake tube. You would be able to spray more than enough to put some truck lengths on your buddy haha
Good morning,
Feel free to give me a call at the shop 254-848-4300 EXT 109 my name is Houston. I would be glad to discuss different options for you and provide you break downs cost wise of options as well. I look forward to helping you out and answering any questions you may have.
