Help with MSD Window Switch!
This thing worked before (last year), now it won't. It had the loops cut when I got it and worked fine. We bypassed the switch & the rest of the system works OK. What is the most likely problem? Ground or is the switch messed up?
I redid the connections, they are good. Then I put a different relay on it, same thing. The full throttle switch is getting power & the MSD is getting power.
Is there a way to see if the solenoids are getting power besides having the engine over 3000 rpms & the micro switch on?
I am really starting to think the MSD is bad. When I started checking the wires, the yellow wire from the MSD was not hooked up to the green of the relay, I thought for sure that was the problem, but nope....
