10lb vs. 15 bottle?
Location: Who said you were allowed to post in The ATLANTA SECTION?
10lb vs. 15 bottle?
necissary?
willl a 10lb go quickly at the track using a 100 shot or so?
how much longer will 15lb last. probly 33% longer right...
as far as track passes. Thanks.
1 Post
Originally Posted by Johns96SS
necissary?
This is a good question.. At $40 a refill... how long does a 10lb last on a 100 shot?
10lbs is good for about solid 7 full passes...u might be able to get a 8th & 9th but pressure will start dropping. a 15lb will hold pressure for alot longer and you'd probably get a good 10 solid passes before pressure drops.
1 Post
So atleast 7 passes at the track..
One more question.. Once a bottle is filled? Does it go bad? How long can you keep it in there before you'll need to dump it and get some more?
1 Post
does a purge have any purpose?
The purge is there to clear the moisture and air that gets trapped in the line out. Once you purge.. pure nitrous is ready to be shot out.
So it just clears the line and readies the nitrous.
Originally Posted by Z28Venom
Thanks for breaking it down..
