Using TNT Power Ring w/ FIPK?
I have a friend who is using the Power Ring with the FIPK, so I know it's possible. His screen name is 00SS4780 if you want to send him a PM--I'm sure he'll help you out.
Josh
Josh
yes you can use it, i have one..it makes it a thousand times easier becuase you dont have to worry about cutting a lid to fit. All you gotta do is cut the rubber piece that goes from your maf to throttle body about 1 inch..(make sure you just cut a very little at a time dont just go hack an inch off..cut a little try it cut a little.etc...) it will take you about 5 minutes..its very easy just make sure you cut the piece evenly so it will seal to the tb/mf depending on which side you cut. i just used a pair of dikes..
