nitrous on a stock 02 Z28??
You "may" want to get a window switch and cut the nitrous before the shift point, just to reduce the strain on the tranny. I have a ws but like a dummy was spraying through the shifts here and there and lost my tranny
i run 200 on mine with no tuning. just did some dynoing today. results here https://ls1tech.com/forums/nitrous-oxide/193922-new-dyno-numbers-today.html
No need for window on A4 (Another myth). Like I said above raise your rev limiter but not your shiftpoints. Up to 150 shot you'll be fine.
My tranny has over 50 passes with stall on 140 dry shot. No problemo.
Dave
If the tranny slips, you shouldn't be shooting nitrous on it, because you'll definately will notice it before you do.
Properly tuned (A word that 80% street nitrous users ignore) the computer will never have a hard time. It's programmed and it executes. The same argument was made by some other poeple who say they would never use dry, because they don't trust their MAF.
All of this is relative to how old is your motor, and how well tuned it is. The same applies to your tranny. Anything over 400 rwtq and even N/A you are playing with fire. Some trannies fair better than others.
Probably wet users should be more consious than dry (Myself). Like Dave says it is not necessary but could be used as added safety.
I opt for not using it on my A4, but I'm getting a FLP Level4 tranny for my H/C swap + juice. And I'll shoot through it too. It is a matter of odds and I lke them on that one.
i spray through mine also. but some people want to be safer than others. predator-z and i are just more brave than others. i'll never use a window switch on my autos. on m6 cars i can see a need for it. missed shifts can do bad things.
