anytone here usung a version 1.1 timing tuner?
Just got this installed and have a couple questions, when you configure the high side nitrous turn off point its says to set the base **** at #8 and set the control to whatever number = turn off RPM. I assume you set the turn off RPM with the RPM **** when you configure it not the WOT or RTD **** - it doesnt specify which **** but I would guess its set with RPM ****.
Also when the car is running I get a steady green LED but the red light blinks once every 5 seconds or so. The red turns on when the n2o is activated but it just constantly blinks when the car is running - wondering if thats normal?
