NOS on truck... a few questions
Here goes:
1. what size shot would be acceptable on a stock 5.3L motor?
2. what size jets (2x) will i need to obtain this ^^^
3. I plan on getting a msd window switch, and I am wondering what a good rpm window would be for spraying the nos.
setup: NOS 5177 dry kit.
Thx for any help you can provide.
i have seen 5.3Ls take a 150 shot pretty good. just make sure you decarbon the engine real good and i would also check your rear knock sensor for water intrusion before you install the kit. truck motors have had problems with this before and detonate NA pretty easy. if you are having these problems, a nitrous kit will just make it worse. also remember that once you install the kit, never put anything but 93+ octane in it ever again. even if you are not going to spray that weekend because it is like a drug and you never know when you will feen another hit
